Refilled and cleaned and leak ink but don't discharge properly
I can fill them to the top and soak the bottoms in hot water and alcohol til the cows come home but they'll still struggle to put out ink properly. Sometimes they'll start to properly then quickly fade and sometimes leave little puddles sporadically. Mind you I DO cover the holes I punctured with scotch tape if that makes a difference.
