Ricoh 171 problem after firmware upgrade
Hello,
I have a Ricoh MP 171 SPF. I had a problem to scan to a folder on Windows 10. I get a firmware for my device from the internet. I updatem my device using SD card and one file using www.
Now my device is starting normal, everything looks ok, i can log on to www interface but printer … can’t print (usb, ip) and scan buton doesn’t work … when i press scan the printer make a sound and nothing happend. On the www interface there are no setting for scaner.
Firmware before update
System/copy 1.01
Network Suport 9.03
Fax 01.00.00
RemoteFax 02.00.00
Network DocBox 1.01
WebSupport 1.05
WebUapl 1.04
GWFCU3-17(WW) 03.00.00
Engine 0.15:04
Firmware after update
System/Copy 1.01 D0675530C
Network Support 9.07 D0675526F
Fax 02.00.00 D0675528C
RemoteFax 02.00.00 D0675524C
Network DocBox 1.01 D0675525B
Web Support 1.05 D0675527C
Web Uapl 1.04 D0675529B
GWFCU3-17(WW) 05.00.00 D0685570E
Engine 0.15:04 D0675540B
May I ask for help ?
regards
Daniel
