Ricoh MPC3002 Problem with rear printing
Hello,
Im from Sweden and new here.
Should try to explain my problem.
In the print setup, I have specified landscape, two-sided, rotate 180 degrees, edge-to-edge with folding to A5 and 2 staples, which gives a booklet in A5 with page 1 borderless and the left edge with a white margin.
On the back I get a white border of about 3-5 mm on both sides.
I go into setup: Yellow button, 107 + C until setup opens.
Question 1: The pressure on the front is adjusted in 1001.2 and 1002.3, but where is the pressure on the back adjusted?
Question 2: I use 2 staples in the back of the booklet. With 6134.3, the upper position of the stapler is adjusted.
Can you adjust just the lower one? Where do I find this adjustment?
