- Feb 13, 2020
Hello! You see, I rescued this old model that we had lying around for quite some time and I wanted to use it for printing my illustrations. However, I encountered some problems:
-"ghosting": basically the last image printed appears in the next one, faded and always yellow.
- saturated: the colors do not match the image desired. Basically when i try to print pastel colors saturated ones appear instead. I'm talking about really dark green instead of soft green, or a red instead of a light pink. It seems that the colors are not mixing properly.
I already clean the whole printer, inside out. One think that I noticed was in the tranfer belt: yellow dust will fall from the inside. I guess this is the cause for most of the yellow fading.
Does any of these problems mean that I have to replace some pieces? Thank you for your help.
PS: if needed, I will upload an image with the illustration printed, so you can see the problem clearer.
