Samsung xpress c1810w open door error
Hi,
I had a paper jam where the paper got stuck around the fuser unit. I removed the fuser, cleaned it and put it back but now I keep getting an open door error. A small latch-type thing came loose in the process and now I can't get it back in its original place. I suspect this is what's keeping the door "open".
Is there a way I can bypass whatever sensor is keeping the door from "closing" ?
Thanks.
Hi!
I’m stuck on the same problem, but can’t figure it out how to put the small things back again. How did you do it? Could you help me in some way?
