Scale change problem
I'm using a XP15000 with a Mac running High Sierra.
Scale change problem:
An original Photoshop composition is printed. A selection is made in the PS document, is copied and pasted to create a new layer. The new layer is duplicated as a new document, is cropped and then printed. The new print from the new document is physically pasted on to the original print. However, the new document has changed size. It is now slightly smaller, so does not fit exactly over the original. The new layer/doc does not appear changed in Photoshop, only when printed. I can't find anything in print settings that would account for this. Any help would be appreciated!
