- Jul 11, 2019
Hi all
i want to send fax over VoIP and I need to turn down the transmission speed on this MFP to 9.6kbps.
I am able to create a fax contact in the address book and set the transmission speed to 9.6kbps and successfully send fax every time.
I need to make the default transmission speed for all faxes to be 9.6kbps.
There are no settings in the GUI to do this, how can i set it in the test simulation menu?
thanks.
thanks.
