- Jun 4, 2016
Howdy folks,
I've not been on here much recently - you know how it is when things are going good
A few days ago my 1400 stopped taking card I was using to print some order of service for a funeral. I managed to finish the print job using another printer but now the 1400 won't take anything - 90gsm copier paper through 260gsm card
I ran a cleaner sheet through and was mildly surprised to see not very much muck on it but afterwards I managed to get it to take paper again - one sheet!
It feel like there's a physical blockage so I had a closer look at the paper feed mechanism. On the right hand side (as you look standing at the front facing the printer) there is a large rubber covered roller and below that a much smaller rubber covered on. Now, if my thinking is correct the larger of the two is driven by the paper feed motor to take hold of the upper surface of the paper and the lower on is sprung loaded to support the lower face of the paper but should be free to rotate (but not driven). I think my problem is that the smaller, lower roller isn't rotating - in fact I can't turn it at all
Does anyone know if I'm right about how this should work and maybe how to free off the lower roller without dismembering the printer?
Any help would be much appreciated
Regards
Steve
Regards
Steve
