Hi yall,
I picked up a stylus pro 7600 from facebook marketplace, yes I know this printer is old and not worth the hassle to get running again but I decided to do it since I don't feel like paying thousands for a wide-fomat, plus I needed something to keep me busy.
Background: I have purged all the lines of any old ink, replaced the dampers with brand new ones, I took out the print head and used a cleaning kit, confirmed all microscopic holes were jetting cleaning solution properly (positive of no blockage). I was able to have a semi successful nozzle check of Cyan, Light Cyan, Yellow, Magenta and light magenta, but black and light black are not printing in the slightest. When I run cleanings, I do find the capping station full of wet black ink, however after running check, no ink for both types. The dampers are full and are not leaking air.
Could the piezo's be dead in the print head by chance, I've been working on this for 3 days, I might cave and buy a new printhead, but I figured I should ask first.
Thanks.
Thanks.
