- Jan 4, 2012
Have a HP LaserJet 2300.
When I print to it from ANY computer (paper tray selected is "auto") it does not take the paper out of tray 1 any longer, it takes the paper out of the main tray 2.
The paper sensor on the printer appears to be working. When I insert paper into tray 1 I do see a message on the LCD display "Tray 1 Env #10".
If I specifically direct the print job from the computer to tray 1 it will print from tray 1.
There must be a setting somewhere in the printer that got changed, that tray 1 overrides tray 2. I have looked through all the menus but cant find it.
Thanks
Thanks
