- Sep 13, 2017
Hi, I was wondering what was the cheapest way to keep my printer head from clogging?
I seem to have to do something every 2 days or a spot can get clogged. What is the cheapest way to push the smallest amount of ink through the print head to keep the ink fresh? According to the chip, since we know that's what controls everything. Does turning the printer on and off do that, and is that the cheapest, or is a nozzle check the best way to go?
BTW if it matters my printer is an Epson XP-640.
Thanks for any advice you can give.
DM
DM
