I would ideally like it to plug in and automatically work like my Samsung ML-2010 that seems to have died. I use 8.04 now but it would be good if it also worked with 8.10.
If you can recommend one that is not autodetect but works well then please tell me the procedure for installing it!
Live in Australia and don't want to pay more than $200 Australian.
Brother 2140 has been recommended by a few even though it rates as "mostly compatible" rather than "perfectly compatible".
Would like it to have toner cartridges that are reasonably priced and be easy to unjam and hopefully not jam very much. Quality of print and speed of lesser importance, especially since I'm no a budget.
Thanks.
Thanks.
