Which Printer Is Best For Using Refill Kits!
I'm trying to find a printer that is the best to use if you use refill kits
for refilling the ink cartridges instead of buying new ink kits.
The printing I will be doing will have both text & a picture on it and
will be heaver paper than regular paper printer paper.
I sure would like that answer as well. It sure isn't proving to be a Canon Pixma! I loved my Epson, but to replace ink was out of my range of affordability. I'd like to find a printer that does only black and I'd have my pictures printed from an online printer.
