White spot at trailing edge on 300 grams glossy Sulfaatkarton with Xerox Colour C60
I have a white spot at trailing edge on 300 grams glossy Sulfaatkarton with Xerox Colour C60. I notice this issue with normal and heavy fuser, I used the corect setting for Coated 3. I tried two different paper stocks namely Invercote G, and MultiCard, both same issue. I also tried lowering the toner coverage to 260 percentage, also same issue.
On normal paper I don't have a issue, for example 90 grams Navigator uncoated or 300 grams DCP uncoated paper.
When I do a Image Transfer (SIQA) test, the toner doesn't stick to the paper (the black is to black, maybe).
Is the white spot on the trailing edge fixable, what's the best approach?
