Hi,
It could be that the network controller need to be reset.
You could log as admin (key button) and go to Software reset > reset both.
Advise you to print a config report before. If possible.
Hi,
xxx.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=453,E=0000000001955886051,K=1314,Sxi=0,Case=obj(8986)
Note you need to add the correct link form.
hope it helps
L.
hope it helps
L.
